I have a '94 LT1 that I want to put into my '95 Z that has a bad knock. Will I have any problems with my original 95 wiring working? I know the 94 distributer is not vented and the 95 is. Any other differences?
1994 to 1995 LT1 engine swap?
Lucky DogTags: None
I would recommend using the 95 opti, if it is good. You'll need to change timing covers to use it. I would also re-use all the sensors off your current setup, the throttle body, etc... You know they work because it runs, right?
If you start using too many parts off the 94 engine, you could end up wth a problem you didnt expect.Tracy
Re: 1994 to 1995 LT1 engine swap?
Here are the part numbers you will need for the switch to the vented 95 opti:
95 GM Optispark 1104032
95 Opti elec harness 12130319
95 Timing cover (with all 3 seals) 12552426
95 GM timing cover gasket 10128293
Opti vacuum harness 12555323
Opti vacuum fitting 14082470
Water Pump Gaskets (2) 10128343
Lucky Dog
Engine hooks?
Thanks for the info guys. Do you have any ideas of how I might make some engine hooks for the top of the motor so I can pull it out from the top? Lucky Dog
Lucky Dog
distributer drive
Is the drive for the distributer the same on the 94 and 95 or will I have to change something?
tabahr
Not only is the 95 up camshaft drive pin considerably longer, but there is also a larger center hole to accept the larger diameter of the 95+ opti male ds. In addition the 94 and earlier cam sprocket has the opti drive pin installed on the gear itself. The 95 and newer cam sprocket's just have a hole in them to accept the longer cam drive pin.
The 94 and earlier cam can be machined to work, but I have a deal you can't refuse!
If you just pay for shipping, you can have my camshaft, opti, and cam sprocket out of my 97 WS6. The opti had about 55K when it was pulled and worked fine. If you don't want a used opti you can still have the cam sprocket and cam.
You are a lucky dog!
Lucky Dog
Better than hitting the lottery.
I'm so Lucky to find this place. I'll take you up on that offer FastTA.
