ok i got this code on my car 2 days now its something with the evap system random purge? what exactely is that and how does it happen and what might cause it?
1441 trouble code
1441 trouble code
1997 Camaro, Z-28, 5.7, Manual 6, K&N cold air intake, custom ram air scoop, ported MAF, Resonator plug, air foil, 160 thermostat, hypertech power programer 3, 3 inch cat-back exhaust, strut tower brace, K&N valve breather, centerforce dual friction clutch, slp short throw shifter, TNL short stick, O2 simulators, Next mod will be 1.6 rockers, pushrods, and springs. any reccomendations?Tags: None
Well, this is the only thing I found about evap system purge, so it might be wrong. but this is code 25.
http://www.alldatadiy.com/alldata/AF...48454/42141374Richard Harvey Jr.
'94 T/A LT1 (stock) - SOLD
ok i think i found the problem
i have a 97 and on my evap system i got 2 switches it looks like. the air from the TB goes to the furtherback on but is that on top or on the bottom? i think when i put my baby back together i mized up the 2 hoses. ken you might know you got a 97 right?
i'm looking all over teh net for an image of the 2nd evap switch but i cant find one anywhere!1997 Camaro, Z-28, 5.7, Manual 6, K&N cold air intake, custom ram air scoop, ported MAF, Resonator plug, air foil, 160 thermostat, hypertech power programer 3, 3 inch cat-back exhaust, strut tower brace, K&N valve breather, centerforce dual friction clutch, slp short throw shifter, TNL short stick, O2 simulators, Next mod will be 1.6 rockers, pushrods, and springs. any reccomendations?
Originally posted by TruckMuddr
I didn't think trouble code were more the 2 digits!!
DTC xx
The GM OBD-II code format, 1996 and newer F-Bodys is 4 digits:
Pxxxx
1441 is "flow during non-purge"..... you can get that from Rob/Shoebox's list. Means the flow detector.... the gizmo BEFORE the solenoid is detecting a flow in the purge from the EEC canister when the purge solenoid is supposed to be closed. Could be a solenoid stuck open, or it could be a faulty flow detector. Not an unusual code and often hard to analyze.Fred
Originally posted by PhantomZ28
B.I.N.G.O!!!!
found it! i love this sight!!
http://shbox.com/1/1996_evap.jpgIt will throw a code if you have the hoses swapped.
