Does anyone know if the stock driveshafts are the same dimensions from 82 - 02? Same length. spline count, and u-joint size?
driveshaft application question?
Tags: None
It's been my understanding that the 3rd and 4th gen driveshafts are interchangeable.Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
I also think they are interchangable. Some companies sell driveshafts and they list 82-02 F-Body for an aluminum driveshaft.1991 Chevy Camaro RS (Is it plum or purple?)
Engine: 305 TBI (L03)
Trans: TH700R4
Mods: Some
CarDomain Site
Just avoid the V6 driveshafts for the LT1 4th Gens... they are "2-piece". I've seen someone post that the LS1 V6 driveshafts are 1-piece, steel and 3" diameter, and make a good replacement for the LT1 V8 shaft, but I've not seen a confirmation of that.Fred
OK, I really want a good aftermarket piece in light of the fact that I want to put my new slicks and rear end to the test, but I cant afford it right now. The temporary plan is to buy a cheap spare shaft incase I grenade mine at the track; then I could just swap in the spare and that will get me home. Then I can employ the old philosophy "If it breaks, fix it bigger and better".96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
Just be sure to run a driveshaft loop.Fred
