Ok, I have the car jacked up, front wheels removed, and going to do lower ball joints and brakes...... I am going to drag the car more than drive it on the street starting this year ( if the weather ever warms up) and would like some suggestions on what do to with the suspension. Should I go to Summit and get the Eibach drag springs or go to T bYrne where he sells just the front drag springs? What about shocks? Summit has KYB AGX (I think thats what they are called) and they are 5 way adjustable, or once again T byrne has the HAL's on sale. I will get to the rear suspension as soon as the front is put back together. Thanks and any alternative suggestions are appreciated. RAY
Suspension mods for drag racing
KYB AGX are worthless for drag racing from everything I have read,if you were autoXing they would be a good choice.
The HAL's are the best for the application and get the springs that go with them to get the maximum out of the shock!!94 Z28/UltraZ Hood & Box/1 1/2 Drop/52mmTB & Bypass/160 Stat/Pulley/ Catback & pipe/Kirkey seats/5 point belts/WW Wing/Ford9"-4.11- Detroit locker-Strange axles/ZEKE'S Heads & LT4 HC/Stainless Headers & Y/1LE Panhard/BMR SFCs-STB-Relo Brackets-Tunnel Brace-Adj Tq arm- Sway bar- LCAs-PHB/ABARE RACING 4L60E/COAN 3200/Monster tach & light/DS Loop
Recipe for running 9.04-sec, 1.3x 60-ft in a 30th SS convertible:
Front:
-QA1/HAL 12-way adjustable/coil over
-QA1/HAL drag springs
-no front sway bar
-front suspension limiters
-PA K-member/a-arms
-Hotchkis STB
Rear:
-QA1/HAL 12-way
-stock springs from a 94 Formula
-Spohn adjustable LCA's
-Spohn LCA relocation brackets
-Spohn adjustable panhard rod
-Wolfe sway bar
-Madman TA, modified by Spohn
-MAC SFC's (modified)
Fred!!! You forgot to mention the 1000+ HP that is needed to move it!!!94 Z28/UltraZ Hood & Box/1 1/2 Drop/52mmTB & Bypass/160 Stat/Pulley/ Catback & pipe/Kirkey seats/5 point belts/WW Wing/Ford9"-4.11- Detroit locker-Strange axles/ZEKE'S Heads & LT4 HC/Stainless Headers & Y/1LE Panhard/BMR SFCs-STB-Relo Brackets-Tunnel Brace-Adj Tq arm- Sway bar- LCAs-PHB/ABARE RACING 4L60E/COAN 3200/Monster tach & light/DS Loop
The QA1/HAL front shocks are only intended to seat HAL springs. You can use the Eibachs, but you would need a custom seat, modifed from the stock seat. Thunder Racing sells them, or you can work from my diagram:
You can use about anything for the back. Stock, V6 springs, Eibach Drag Launch, etc. I have the Eibach Drag Launch in the back, which I got in trade for my stockers that went on the 30th SS convert. The Drag Launch springs raised the back end up another 1/2", making the already ridiciulous space between the fender and the tires even larger.Fred
