Hello,
I've been having a gradually developing starting problem over the last year. I have tried many different things to fix it and have been to many different mechanics for assistance, etc. After the car has been sitting for awhile, it has a difficult time starting, like it will crank for about 10 sec or so and then finally fire up. The car runs fine once it's going. I've had new fuel injectors put on, a fuel filter, 2 different sets of plugs/wires, new opti, coil, various coil wires, new battery...problem is still here. It also seems that the car takes longer to start when I have less gas in the tank...i.e. like a half a tank...it seems to start somewhat faster when full.
If it was a dying fuel pump, would the car work ok while I'm driving for a year? I would assume that I would run into more problems if it was the fuel pump and not just starting.
Could it possibly be simply the starter all along? I just need some advice because I'm running out of money. There are no codes being thrown at all by the PCM.
Any ideas would be most helpful! Thanks!
