95z28 sizspeed,mosewr 12 bolt with 4:10, bmr suspension upgrades, 150 shot of nx through a direct port kit, je pistons, eagle rods bored .040 over, afr 190cc heads, 2.02/1.6, zz409 cam with 1.6 rocker. .544/.544 lift, exhaust cutouts
what should i run?
Its very hard to say.......With just the 150 shot on a stock motor, you'd be getting low 13's to high 12's. With the heads and cam - I would guess low 12's depending on how well its been put together and how much traction your getting. Only one way to find out though......96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
11.6 @ 123mph (1.6 60' - getting there)
The 150 shot alone should get him a strong 12. I think combined with his head/cam combo and his gearing he should be able get a low 12, and more likely a high 11 considering a good 60ft and reaction time.
Practice slamming those gears!!
So we've brought you down from 13's to 12's to 11's. Do I hear 10's?96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
