Is there anyway to make a custom cone filter intake with parts from a hardware store? I want to put an intake on the Bird but dont feel like spending $200+ for a couple pieces of plastic and a filter.
Homemade Intake
of course there is... you just have to take measurement..and then find the materials that work for you... be aware of things like heat and such which could melt plastics and some lighter metals too. you pay big bucks because someone has done the time and research to be at least fairly sure their product is safe and hopefully provides gains.
I made one for an 88 TPI bird. It worked O.K.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
I was thinking of running some 4"ducting material from the oval openings on either side of my license plate, removing the old air filter and joining the two ducts into one and running it to the throttle body. I don't think this is gonna cost but about $100 for the parts and acouple of hours time.
Phil
Back in 93, I relocated the stock airbox to the bottom of the nose of my Formula. There's a plastic piece that unbolts from the bottom, sorta triangular in shape. I cut a hole in it for the neck of the box to peek through and ran ducting from Home Depot through the metal opening under the oringinal space where the filter box resided, to a 4" double male PVC fitting right to the stock elbow. (I had speed density). I cut away the last 6 inches of the plastic strip under the nose and that cleared the airway leading to my little 'ram-air' setup.
I actually saw the fruits of my labor at the track. Picked up a best of .15 secs and like half a mile an hour or something...but then again, I didn't build it at the track, so who truly knows if it worked or not, lol.
1998 TA M6 SLP Lid, Cold Air and Bellow, Flowmaster 3", Centerforce DF, Fast Toys MAF ends, JET skip shift eliminator 312rwhp/366rwtq
92 Lincoln Mark VII LSC For Sale
Visit Central Jersey Mustangs & Fords
mikey2423
if you have a muffler shop in your area get them to take a 2 3/4 -3 1/2 in pipe and custom bend it to fit your car, and then you can polish the inside to let the air run smoother, and powder coat or idonize it to give it some color. when your done with that just put a decent after maktet cone filter on the end of that for some decient hp gains
mikey2423
