Well it took me 3 days but the results are worth it. The directions say it should take 3 1/2 hours. Lots of little things that make this job frustrating for the first timer.
I put in 2 washers. Even part throttle I chirp gears. I'm glad I didn't put in 3.
I was worried because the fluid looked so bad and smelled burnt, but I put in Mobil 1 sythetic ATF so maybe it will be good for a couple more years.
Anyhow I'm happy now
Bob
95 Formula Ragtop A4, Transgo Kit, Throttle Body Coolant Bypass, LT4 Knock sensor, Taylor 8mm Wires, NGk Plugs, Upgraded AIr intake, Descreened and ported MAF, relocated air sensor, Magnaflow 3" catback, Kumho tires, Mobil 1 fluids
Bob
,SLP~Shorty headers, LoudMouth, Air Foil, LineLocks. Catco Cat. Hypertech 160. TB Bypass. MSD~8.5mm. Walbro 255lph. FT MAF ends. LT4KM. BMR~Adj LCA's, Rear sway, Panhard rod. HAL QA1 rear shocks. Random Tech adj TQ arm. Nitto NT555R's. Covered in Zaino. 13.466@103.85 N/A.
13.410 @ 102.66 11/20/05]
There is a little more vibration and noise, but it is livable.
