I have a 95 six speed, but I was wondering if there was a company who offerered a beefed up six speed because I want to keep a stick
beefed up manual?
What kind of power are you making that you need to beef up a T56?96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
Does a G-tech count? - I figure im making over 500 horse on the juice. I have abused my T56 in every way imaginable and it keeps coming back for more. I have heard one of the guys on this board talk about them holding up to 900 horse power. Thats probably stretching it, but they are pretty beefy. I know one of the good upgrades is beefier shift forks.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
There's an outfit called D&D Peformance that specializes in the T56, offering everything from heavier input and output shafts to ogenic treating. I ran the T56 to about 635flywheelHP and had no problems. A buddy of mine pushed his to about 800HP in a 3,900# convertible with no problems. Rich Krause who moderates the "Drivetrain" forum at CamaroZ28.com ran his T56 at about 900HP on a blower + nitrous car, another 4,000# convertible. "Taner" who posts on CamaroZ28.com is running mid-9's/14Xmph with a T56, but it has some significant upgrades.
D&D PerformanceFred
