so let me get some feedback from you guys. Say you have 2 of the same f-bods, except one is an a4 and 1 is an m6. Whos gonna get the best time in the 1/4. I always thought it was the automatic
M6 or A4 in the 1/4
auto- unless the driver is VERY VERY good
TrAnS Am 98 -
It's funny, I have raced many similarly equipped f-bodies to me at the drag strip, and I have only lost twice...
...attribute some it to some of the drivers getting atrocious 60' times or manuals not shifting properly... but I have only lost twice... one of those losses was by 0.0603 seconds at the finish, but I was 0.2 seconds faster (I ran 13.1, he ran 13.3). The other was run last fall before I knew I had bent pushrods under the hood and I ran a lackluster 13.6. As a M6 driver, I have a pretty dern good W-L record
against *similarly* modded cars of course, lol...
What brand of high stall torque converter is good to get?Mixedpuppy
1998 TA, mostly stock, SLP hood, ram air plastic intake, K&N Filter, Transgo Shift Kit, Kooks Stainless LT headers with Magna Flow Cats, Borla Exhaust (Medium plate setting), Kenny Brown SFCs, BMR Tower Strut Brace, 17" ROH RT Rims, 9.5 BFG KDWs, SLP Airlid, Smooth bore bellow, 85mm MAF. Nitrous to come. Action figure not included.
Ive heard good things about the Vigilante Torque Converters, but they seem a little pricey!Originally posted by Mixedpuppy
What brand of high stall torque converter is good to get?1996 Arctic White Z28, A4, K&N CAI, TByrne MAF ends, BBK Twin-52mm TB, TB Bypass, SLP 1 3/4" Shorties, Richmond 3.42's, Dynomax Bullet Muffler W/Turn Down, BMR Adj. Panhard, EIBACH Pro-Kit, AFS ZR1 Wheels W/17x11" out back!
I've posted this before, but I always recommend a CUSTOM TC. IT is impossible to build mass produced torque convertor that will have an accurate stall in all vehicles equipped with the same tranny. WHen I was running autos, I would go to the guy who builds all of the convertors for the shop. HE would ask the race weight of the vehicle, cam, intake, heads, and all other pertinent info, so that he could build a convertor that actually had an accurate stall speed in the car.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
I think the fun factor is important to be considered... I love rowing through the gears. And since the manuals are harder to launch, I tend to play catch-up a little bit. There is nothing that brings a smile to my face as much as a come-from-behind victory mid-track
Re: M6 or A4 in the 1/4
This is an age old argument that has been going on for a long long time. The auto is going to give you more consistent times along with more consistent launches (removes driver error with shifting)...I would definitely be more inclined to use the T400 for high HP applications (700hp) and above on a primarily 1/4 mile car. However, If the person driving the manual is good and gets a good 60' time as well as hits every shift, (stock for stock)...the guy with the auto is toast especially with the gearing advantage of the manual and the HP loss of the automatic. Although, even the best driver will launch the manual as well as shift through the gears different every time occasionally missing a shift thus going down to the auto from time to time. The advantages of the manual are obvious on a road course or any application that has turns, accelerating and decelerating. The T56 LT1/LS1 setup is pretty cool, and it gets my vote, but it is not for everybody. Most of it is about personal preference. However, NOT a big fan of the soft/spongy LS1 stock clutch...YUCK!!!...what were they thinking???Originally posted by WS6 freek
so let me get some feedback from you guys. Say you have 2 of the same f-bods, except one is an a4 and 1 is an m6. Whos gonna get the best time in the 1/4. I always thought it was the automatic'77 K5 rock-crawler project
Thomas Jefferson
