That engine sounds like a great deal. A Pontiac 400 engine for around $1100 is a great deal. If I had the money I would buy it!
About your questions:
About him calling it a 400 and a 406 block, I don't know
You can still buy performance parts for your 400. Everybody has different opinions on what is better than what. Do your own research and pick what you want for performance parts. Everybody will tell you something different.
You usually have to reset valve lash after you run the engine for a while (especially on flat tappets lifters, not so much on hydraulic lifters) since the rockers move so much and can't be adjusted in the best position without the engine running or turning for a while (somebody can explain this better than me, I'm still a newbie to certain aspects of engines).
When he says 10-10, he is saying that the crankshaft was ground down .010" on the main and rod journals. This is pretty typical for an engine rebuild.
I would go for the roller tip rockers and cam, too. It is also worth it, in the long run. Good luck!!
