GM's LT4 kit http://www.gmpartsdirect.com/results...ber=pk12550630
This LT1-to-LT4 conversion kit brings the most out of your factory LT1 engine. The kit includes LT4 cylinder heads with valves and springs, a red aluminum LT4 intake manifold, GM Performance Parts' HOT cam with 1.6:1 ratio Bow Tie roller rockers, and all necessary gaskets. The result of all of these modifications is 425+ proven horsepower!?????
or
http://www.lt1f-body.racenet.net/valvetrain.php
Racenet Performance Stage II Street/Strip Power Pack includes everything you need to turn your LT1 Camaro or Firebird into the Beast it was meant to be. This proven package will safely & reliably add 75-125+ RWHP to your LT1 engine.
Each Package Includes:
Racenet Performance Stage II Street/Strip Cylinder Heads
Racenet Performance Ported & Polished Intake Manifold
Competition Cams Camshaft of your choice
Your Choice of Competition Cams Pro Magnum Rocker Arms & Hardened Pushrods or BBK 52mm Throttle Body
Complete Top End Gasket Set
ARP Cylinder Head Bolts
OR somethign else?
or
OR somethign else?
