Finally finishing up the suspension in the rear. My BMR order finally came in for the rear sway, and panhard rod. So, I went to install those, plus the Random Technology adjustable Torque Arm. Figured I would do the torque arm first, then sway, then panhard. As for the Install.... I am pretty darn stumped on this one! The stock torque arm was on there pretty good. Took a couple whacks with the rubber mallet to pop the rear section off. Now I can't figure out how to get the back section of the torque arm to align correctly with the rear end. It seems like the rear end is about 3/4" to 1" off, and on a strange angle! If I jack up the rear end, all it does is pretty much lift the back of the car off of the ground. Where am I going wrong??? Almost about ready to get out a prybar and make it fit!
Could really use some fast f-body guru help, was going to try to make it to Island Dragway on Sunday - although 10am doesn't look too good now. Thanks
13.410 @ 102.66 11/20/05]
