i was wondering how do you remove your air contionor off the lt1 is there a kit to put a pully in the spot
pullies
Got this off of www.gmpartsdirect.com
GM PART # 10115875
CATEGORY: Water Pump Pulley
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $59.81
OUR PRICE: $34.09
DESCRIPTION: PULLEY AS
a/c delete pulley with bracket on 93-95 f-body cars with option code 1LE and C41
I heard it takes 2-3 weeks, since they have to special order it.
Here is a Picture of it.
Richard Harvey Jr.
'94 T/A LT1 (stock) - SOLD
ok this is what I found out.
The A/C Compressor mount is the same part number from 93 to 97. So it should work. The only reason I could find for it saying it stops at 95, is because the LE1 package came with the A/C delete untill 95, when A/C became a standard option.Richard Harvey Jr.
has anyone had a dyno run after removing the air to see if there is a horsepower gain like when adding a electric waterpump. if so call my a/c gone1994 Trans Am GT
http://www.sounddomain.com/memberpage/208684/1
Ram Air hood and airbox
headers
exhaust
lowered 2"
underdrive pully
sloted rotors
electric water pump
air foil
denso plugs
taylor wires
tinted windows
eagle rims
2000 watt stereo
Well, if you think about it, if your A/C is turned off, it is doin the same thing as just a pully sittin there since the clutch isn't engage. So I don't think you would gain much if any. One benifit wound be the weight lose from removing the A/C system.
Just my thought on it.Richard Harvey Jr.
The HP gain you will see from deleting A/C is a very small amount, the result of rotating mass reduction on the outer ring of the electric clutch - probably too small to see on a dyno. Nothing else turns when the A/C is off. The only measurable "gain" from A/C deletion is the 45-55# of weight savings (depending on how many of the components you delete).Fred
that is what i thought. but my next qurestion was going to be how much weight you would loose. that is about half a tenth to sweat your butt off, think i will keep it.1994 Trans Am GT
headers
exhaust
lowered 2"
underdrive pully
sloted rotors
electric water pump
air foil
denso plugs
taylor wires
tinted windows
eagle rims
2000 watt stereo
