Is it drag limited or is it redline in 5th gear?
Top Speed for a M6 car...
I have heard that sixth gear doesnt do much good (drag limited). So I guess 5th gear redline would be it....96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
Could you drive to the top of 5th though?Originally posted by Rob
Top speed, with the stock 3.42 gears, was in 5th gear. 6th wasn't drag limited, it was power limited. Just couldn't pull the rpm with the .5:1 ratio.
4.10 gears would make 6th gear the top speed gear as the extra ratio would allow it to pull some more rpm.Former Ride: 2002 Pontiac Trans Am WS6 - 345 rwhp, 360 rwtq... stock internally.
