I am looking at the lt4 hotcam. Anyone currently running it? How rough is the idle? How much of a difference did it make?
LT4 hotcam
Are you prepaired to change the OPTI to vented and the front timing cover to accept the vented OPTI?2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Last fall I put in a '96 engine and the Lt-4 hot cam kit with roller rockers, and HD timing chain and gears from Dal Salbaugh at Van Dere Olds. Good price for the stuff. Seems "gutsier", and power comes on above 2000. Ilde is nice lope, but not one that needs reving to keep running. I have NOT done the PCM program yet, which should bring out the power in the kit. I am satisfied so far.
You should change the timing cover and the opti to '96-'97 for the vented unit. I also added a small vacum hose off the weep hole of the water pump and routed it to the steering rack, so when the pump fails, the coolant stays off the opti and goes to a noticeable spot.The Old Guy! '94 z-28, m-6, t-tops, go-fast red, 316k. Now with '96 engine w/ Lt-4 hot cam, roller rockers, heavy duty timing chain, and Spec stage 2 clutch.
The drive mechanism is different for the non vented http://shbox.com/1/93-94_opti.jpg and the vented http://shbox.com/1/opti_back.jpg OPTI. The LT4 hot cam (from what I've heard here) has the drive key for the vented OPTI. Therfore to use the LT4 hot cam you have to switch to the vented OPTI which forces the use of the 95-97 timing cover. http://shbox.com/1/engine_front_diagram.jpgOriginally posted by 94 formula
Why do you have to change to a vented opti.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
You should verify which drive mechanism that cam has before you buy it. 93-94 or 95-97.Originally posted by 94LT1Z28
Thanks for all of the info. I actually found a comp cam that I like a lot better. It has less lift, but quite a bit more duration. I will let you guys know how it turns out. Thanks again2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
