I failed the OBDII test. The following 3 trouble codes came up:
P0161 - O2 sensor heater circuit
P0420 - Catalyst System Efficiency Below Threshold
P1416 - No DTC Definition Located
Does anybody understand what these are. The car seems to be running perfect, however I need to get them corrected in order to pass inspection. Is the dealership going to charge me an arm and a leg to correct this? Please help.
13.410 @ 102.66 11/20/05]
