my 93 formula has a glove box sticker with a code of gu60 i think .can i change the the gears in this axle as i have read that some axles have differant crown wheels and you can not get gear sets for them or am i getting confused
what axle do i have
what axle do i have
mirror burn out movie top ten burn outsTags: None
Re: what axle do i have
GU6 is the 3.42 rear. That is the larger carrier, so you can use bigger gears if you wish without changing it.Originally posted by bigtow
my 93 formula has a glove box sticker with a code of gu60 i think .can i change the the gears in this axle as i have read that some axles have differant crown wheels and you can not get gear sets for them or am i getting confusedTracy
Check your build tag again... I have never seen a "GU60" code.... they are all 3-digit as far as I know. And there was never a GU6 used in the 1993...... rear axle codes:
M6 with 3.36 1st gear (M28) came with 2.73 gears (GU2)
M6 with 2.97 1st gear (M29) came with 3.23 gears (GU5)
A4 with "standard" axle came with 2.73 gears (GU2)
A4 with "performance" axle came with 3.23 gears (GU5)
The problem with swapping gears relates to the size of the "carrier"..... the center part of the differential that holds the ring gear, and includes the spider gears and limited slip mechanism.
The 2.73's were installed in a "2-series" carrier. The 3.23's were installed in a "3-series" carrier. You must buy gears made specifically for the "series" carrier in your car. It relates to the space available between the ring gear mounting surface and the pinion shaft centerline.
Before you can change gears, you really need to know exactly which trans you have and exactly which gears the car came from the factory with. The "rules of thumb"..... 4.10's for an M6.... do not apply to 1993 M6's. You would have way too much gear with 4.10's in a 1993 with the M28 M6.
Which trans do you have?
Which RPO code do you have for your gears?
What is your goal for upgrading gears?Fred
gears
i will check the code my car has a auto trany. after having a go at drag racing the other week i want to improve my times at the striphttp://www.pontiacdriversclub.co.uk/ keeping it pontiac in the the uk. 93 formula a4 ZR1 rims
opps
sorry my code is gu5 does this helphttp://www.pontiacdriversclub.co.uk/ keeping it pontiac in the the uk. 93 formula a4 ZR1 rims
so how many splines is it, if i have the gu5 code?2006 GTO Impulse Blue Metallic, Blue Leather Interior
Traded in: 1998 Z28
GU5 is the 3.23 gears. They are in a 3-series carrier. That carrier accepts gears of 3.23 and higher (numerical). You could get 3.73's or 4.10's for that carrier. But which transmission do you have - A4 or M6?
The number of axle splines doesn't change with the gear ratio. I'm pretty sure all the 4th Gen 10-bolt stock setups are 28-spline.Fred
auto
does a4 stamd for auto if so i have a 4l60 not electroinc in to which i am having a compertsion shift kit fittedhttp://www.pontiacdriversclub.co.uk/ keeping it pontiac in the the uk. 93 formula a4 ZR1 rims
Yes.... "A4" = 4-speed automatic. 4L60 in the 1993. 4L60E in the 94 and newer models.Fred
