i am putting a electric water pump on my car while i am putting in the new optispark. i was told i needed to remove the shaft that comes thru the block but it seems to be riding on a bearing or seal or something and it is stuck in there pretty good. do you have to remove this shaft? is there somthing that will happen if you leave it? i just do not know i have a install proceedure that says nothing of it and i can not find anything anywhere that does mention it one way or the other. please help i am ready to drive my baby agian.
elecrtic waterpump install
Much better instructions:
http://www.ws6.com/kelley-wp.htm
Even has pictures of the brass freeze plug install.
those are the instructions that i am using and they do not mention the shaft coming from the block at all. that is why i asked agian.1994 Trans Am GT
http://www.sounddomain.com/memberpage/208684/1
Ram Air hood and airbox
headers
exhaust
lowered 2"
underdrive pully
sloted rotors
electric water pump
air foil
denso plugs
taylor wires
tinted windows
eagle rims
2000 watt stereo
fownd two answers to this question. csi say remove it but it is optunal. meizer makes no mention of it. it is a major dissasymbly to do so. you have to pull the timing cover so that means, waterpump, opti, pulley and pully snot.1994 Trans Am GT
headers
exhaust
lowered 2"
underdrive pully
sloted rotors
electric water pump
air foil
denso plugs
taylor wires
tinted windows
eagle rims
2000 watt stereo
www.ls1howto.com covers the install, step by step with pictures. Hope that helps.2006 GTO Impulse Blue Metallic, Blue Leather Interior
Traded in: 1998 Z28
