my battery has just given up the ghost all of a sudden the hydrometeris showing green and the charge meter is showing 13 volts but the starter just turns once then clicks if you put a boost pack on it will start at once. if i put a multi meter on the battery it shows 12.3 volts with the key off as soon as you turn the key on bot not to start it drops to 10.2 volts is it my battery or altenator i have not been able to check the out put with the car running any clues?
ps this car is my daily driver so i need help quick if poss
