A few weeks ago an older guy at work told me "Now don't go double clutching with that new clutch...you will ruin it". Now this guy has been around fast cars for sometime (hes like 55 years old). I always thought double clutching was something old trucks did to disengage the clutchand rengage it properly. I thought fast and furious just brought that phrase back (becuase they are really stupid and do not know much about cars). I am I wrong? What is double clutching?
double clutching
You're right on the money on all counts. Vin Diesel (not his real name) is a Hollywood sellout, not a car guy. "You were granny shifting when you shoulda been doubleclutching..." Yeah Vin...We know. Look at it this way, it confuses all the ricersOriginally posted by stingant0A few weeks ago an older guy at work told me "Now don't go double clutching with that new clutch...you will ruin it". Now this guy has been around fast cars for sometime (hes like 55 years old). I always thought double clutching was something old trucks did to disengage the clutchand rengage it properly. I thought fast and furious just brought that phrase back (becuase they are really stupid and do not know much about cars). I am I wrong? What is double clutching?
Originally posted by Kevin - Blown 95 TAVin Diesel (not his real name)
Vin Unleaded didn't have the same ring to it...I hate what that movie brought to pop-culture and wish it had never come out.-Rico
http://www.driversedge.com/dblcltch.htm
I was confused too...when I saw the movie, they went straight...but double clutching deals with cornering...
Double clutching is shifting the gears without the clutch where you pull the shifter out of gear as the RPMs decend after the peak and place it into gear on the same stroke...sometimes, depending on how good you are, you have to tap the accelerator slightly to get the second RPM decend to get back into gear. You really don't need a clutch except to get the vehicle moving. Pretty much all truck drivers drive this way. My brother-in-law drives his big utility trucks this way, and I drive my Blazer this way. I don't know much about the lines in the "Stupid and the reckless", but this is what the pharse referes to.
I wouldn't drive my T/A this way...too great a possiblility for error especially if your ripping through gears...start breaking stuff. I just rock my clutch as I go through the gears...same effect. If you watch the good road racers, they rarely use their clutch, but then again...they can afford to break their equipment.'77 K5 rock-crawler project
Thomas Jefferson
so the quote goes... Granny shifting, not double clutching like you should.... and so on. I for one loved the movie. Yea i knew he was wrong there and i know hes not a car guy, but he also didnt write the script some dumb@$$ hollywood writer did. And that guy is obviously a ricer who knows nothing about cars. Especially when Ja Rule looks under the hood and can tell that "Hes got enough NOS in there to blow his self up" lol.
-ken-
oh and i thought in the older days the double clutched meaning - clutch in, take it out of gear, clutch out then back in to put it in gear? i thought this is what syncros took the place of.~~~The Twisted One~~~
My 30th is gone but soon a new era will begin.
Right again. I can shift w/o a clutch on a manual trans, but I don't double clutch it. Just blip the gas off while matching rpms and shift into the next higher gear at the instant the drivetrain is unloaded. Harder to do going down a gear.Originally posted by Ken(Bone Breakin Chevy)oh and i thought in the older days the double clutched meaning - clutch in, take it out of gear, clutch out then back in to put it in gear? i thought this is what syncros took the place of.
I took a riding school for sportbikes - Team Hammer Suzuki Endurance - we did drills where we would go up through all 6 gears and back down again over and over again. You learn the sound of the engine in all the gears and know when to shift. In racing, you lose time if you throw out the clutch every time you shift. We just put slight pressure on the shifter, blip the gas, match rpms (more important on downshift), and shift. The gears are backcut on the bikes which means that you don't hurt them when you shift this way. Takes a little practice with a car, but it's the same principle.
Nope... "heel-toe" shifting deals with corneringOriginally posted by LimTeng99TransAmhttp://www.driversedge.com/dblcltch.htm
Not really. Double clutching actually uses the clutch. Hence the name "double clutching".Originally posted by markd79taDouble clutching is shifting the gears without the clutch where you pull the shifter out of gear as the RPMs decend after the peak and place it into gear on the same stroke...sometimes, depending on how good you are, you have to tap the accelerator slightly to get the second RPM decend to get back into gear. You really don't need a clutch except to get the vehicle moving. Pretty much all truck drivers drive this way. My brother-in-law drives his big utility trucks this way, and I drive my Blazer this way. I don't know much about the lines in the "Stupid and the reckless", but this is what the pharse referes to.
Here is a good explanation:
http://auto.howstuffworks.com/transmission4.htm
94_Formula
double clutching
Double Clutching is when you're in a gear like 3rd and you're doin about 30 or 35 something slow and then you push in the clutch rev the car while the clutch in not to long and dump it. It will make the car launch much quicker.
94_Formula
Double clutching was something that was done in cars that were made pre-70's. Their transmissions did not have sysnchros at all so they had to actually push in the clutch twice to shift. It is not done in all of our modern transmissions. Some, but very few heavy duty machinery transmissions that use straight cut gears and no synchros still use this process. The term "double clutching" is commonly used wrong by alot of people.
Quote from howstuffworks.com:
"In double-clutching, you first push the clutch pedal in once to disengage the engine from the transmission. This takes the pressure off the dog teeth so you can move the collar into neutral. Then you release the clutch pedal and rev the engine to the "right speed." The right speed is the rpm value at which the engine should be running in the next gear. The idea is to get the blue gear of the next gear and the collar rotating at the same speed so that the dog teeth can engage. Then you push the clutch pedal in again and lock the collar into the new gear. At every gear change you have to press and release the clutch twice, hence the name "double-clutching."
As an officially certified "older guy", you are correct. That's what we did.... clutch in to move it into neutral, clutch out - blip the throttle to match the speed of the next gear, clutch in and move it to the next gear. This was necessary on trannies without synchronizer rings, or you would grind the crap out of the gears.Originally posted by Ken(Bone Breakin Chevy)....
I learned how to drive on my dad's 1941 Ford pickup, with a 3-speed no-synchro manual box, and a 2-1/2 foot tall lever sticking up out of the floor.Fred
