Alright, so i'm driving out to my girlfriends house which is about 30 miles away. I get on the parkway and shift it into 5th. Everything is nice and smooth but i want that extra gas mileage so i go to 6th. Shortly after that, the Service Engine Soon light came on. The car wasn't bogging down or anything. As i got closer to her exit, i dropped it into 5th and the light went off instantly. Same thing on the way back. In 5th, i was doing 60 and it was at around 2,000 RPM's. When i did 60 in 6th gear, it ran at around 1400 RPM's. Thanks in advance for any help.
Is this normal?
Is this normal?
SOLD- Kinda miss it
SOLD- Good riddance!
2006 Ford Fusion: 2.3, 5 speed, could run 15lbs of boost with a 150 shot and it'd still be slowTags: None
Get it scanned.... the code is stored in the PCM, and will remain there for a while. If I had to guess, I would say you will find DTC 32 for the EGR system. It's fairly rare on the OBD-I cars, but it can happen under moderate load/low rpm conditions, when the EGR is required to reduce the combustion chamber temperatures, and reduce NOx emissions.
JUst remember, your 95 is an OBD-I PCM, but the ALDL connector is the 16-pin OBD-II style, which confuses most shops, when they hook up an OBD-II scanner, and it won't work.Fred
There's lots I don't knowOriginally posted by Dave Mfred, is there anything you don't know?
..... I just don't even try and answer those questions. Part of "looking" smart is knowing when to keep your mouth shut.
A lot of the answers I post are just recycled info from posts I've made over the late 6 years on these boards. A lot of these questions get posted every few months....
