Is the optional hurst any good? What is the difference between that and the stock one? Does it allow more accurate shifting (ie getting it into 3rd), and does it have those little bolts to stop the shifter from traveling too far?
hurst shifter
If you mean the SLP Hurst "optional shifter".... its a mixed bag. It is a Hurst shifter, and it is sort of similar to the Hurst "Competition Plus" aftermarket shifter (long since discontinued and replaced with the "Billet Plus"), but it isn't the same. The SLP unit makes you reuse the stock shift lever, with its big flexy rubber bushing, and that where a lot of the sloppiness comes from. The "real" Hurst has a metal lever with no bushing. And, the cover on the SLP unit isn't as heavy as the real Hurst, and there are no stop bolts... at least there were not on the one I got along with the T56 from a friend's 30th SS.
If you want a good aftermarket shifter, with very accurate 2->3 shift, get the Pro 5.0 shifter.Fred
The Pro 5.0 and the B&M Ripper are both really good shifters. I personally like the Pro 5.0 much more. It feels much more solid. And the 2-3 shift is a no-brainer!
Pro 5.0 is even so confident that they have a 30 day money back guarantee. Even if it has been installed. That is impressive.
