Hey People I'm new here, and i need some help, I've been looking eveywhere for a t-56 conversion to stick in my 1967 Camaro. Right now it sports a factory M-21 muncie 4-speed and it's never been touched but its getting worn out and doesnt shift like it used to, and i can understand that and i thought it would be awsome 2 put in a t56 because with the 4:10's in the rear my highway gas milage sucks and im cruising at about 4,000 rpm's doing 75-80 mph when ever im on the highway.So I've heard about bell housing company's make that a t56 can bolt up to and run on other chevy blocks not just the Ls-1's or Lt-1's but I havent seen anything like that anywhere?? HELP!!!. Well I would appreciate any help you can give me.
T-56 conversion into a 1967 Camaro
McLeod makes a "universal" bell-housing to adapt most T56's to most existing blocks.
http://www.mcleodind.com/
There is also an outfit called Keisler, and their products have been featured in two recent issues of Chevy High Performance:
http://www.keislerauto.com/Fred
Why not just use one from a LT1?? isnt the bolt pattern on a LT1 the same as gen1 SBC?Originally posted by RocKin1967Hey People I'm new here, and i need some help, I've been looking eveywhere for a t-56 conversion to stick in my 1967 Camaro. Right now it sports a factory M-21 muncie 4-speed and it's never been touched but its getting worn out and doesnt shift like it used to, and i can understand that and i thought it would be awsome 2 put in a t56 because with the 4:10's in the rear my highway gas milage sucks and im cruising at about 4,000 rpm's doing 75-80 mph when ever im on the highway.So I've heard about bell housing company's make that a t56 can bolt up to and run on other chevy blocks not just the Ls-1's or Lt-1's but I havent seen anything like that anywhere?? HELP!!!. Well I would appreciate any help you can give me.Tracy
I was going to say the same thing but I'm not 100% sure. I think I read that somewhere.Originally posted by TraceZWhy not just use one from a LT1?? isnt the bolt pattern on a LT1 the same as gen1 SBC?2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
As far as I know its the same to 97, but I do know there is some differences after that, not sure if it is the bell housing or not but I know for my 89 (gen 1 block) it is a direct repacement upto 97, then you need some special kits to put it in. I think this is mostly due to the new clutch system and the trany is longer after that, which may not be a factor for 67'
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
correct.. 1n 1998 came the GEN3 LS1, which is a completely different motor. SO, up to 97, the GEN1 and GEN2 SBC shared the same bolt pattern. In fact, they Are essentially the same motor, with monor changes.Originally posted by DeWynterAs far as I know its the same to 97, but I do know there is some differences after that, not sure if it is the bell housing or not but I know for my 89 (gen 1 block) it is a direct repacement upto 97, then you need some special kits to put it in. I think this is mostly due to the new clutch system and the trany is longer after that, which may not be a factor for 67'
I'd bet it would fit... Can Anyone confirm this?Tracy
