so along with the mods i have now, i was thinking about some subframe connectors and lower control arm relocation brackets, im looking to go the cheap route, where is the best place to purchase them, and will i see a difference in the ride and performance from my car?
subframe and relcaion brackets
I got my sub-frame connectors from Don Goetz great product and service
he can be contacted here dgoetz3@cinci.rr.com1997 Trans AM WS6 vert
1 of 463
LT4 knock module
strut tower brace
SLP fan switch
160* t/stat
Pictures Here
Funny you say that about the relocation brackets. I just got done putting mine in! Along with new lower control arms. I bought them from lmperformance. I've noticed a great increase in traction already. My car is lowered, so the brackets were way off and now the arms sit parallel to the ground like they are supposed to. Install was very easy as well. The hardware kit, was well worth it, the old bolts were rusty and a pain to get off, so I'm glad I did not reuse them. I had a lift for my install, used two types, so I didn't have to use jackstands or ramps. I plan on taking it to the track shortly, within a few weeks, so I can let you know results of that. If you need help with the install, installuniversity.com has good instructions with pictures. If your car is 98 or newer you have to cut the e-brake bracket, no big deal, the dremel came in good use. I believe if its 97 or older you have to cut one of the caliper weights, thats on bmr's website. bmrfabricatoin.com Again, this is the route I took, here's what I used:
Brackets, bolt on.
Control Arms
Hardware Kit2006 GTO Impulse Blue Metallic, Blue Leather Interior
Traded in: 1998 Z28
Don makes bolt on must folks say the weld on are better and that is probaly true but I want the ability to put the car back to factory they make a HUGE difference 98% of the creaks and rattles ard gone and the handeling cannot be described you just have to drive a F-body with subframe connectors to feel the diff you would need to contact Don for the current pricingOriginally posted by redbird94how much did they cost,were they bolt on or weld on and wut is the difference
MY 02c if you dont have sub-frame connecto0rs get them !!1997 Trans AM WS6 vert
1 of 463
LT4 knock module
strut tower brace
SLP fan switch
160* t/stat
Pictures Here
Hello,Originally posted by redbird94so along with the mods i have now, i was thinking about some subframe connectors and lower control arm relocation brackets, im looking to go the cheap route, where is the best place to purchase them, and will i see a difference in the ride and performance from my car?
I would like to work with you if you would be interested. We are a site sponsor, we carry both the weld-in SFC's as well as the weld-in relocation brackets. All products are a 100% quality and satisfaction guaranteed. I will list a few prices below, please contact me by email if you would be interested in pics or info, I have plenty to send. Thanks for your time.
Boxed Weld-In SFC's- $139.99
Weld-In Relocation Brackets- $59.95
