So the Master cylinder is fine.....
Next step trans out.
It'll either be a problem with the slave .... which is not leaking, so it's probably OK (remember it was a new 2002 GM part when I installed the trans .... 25,000 miles ago).
Or.... that stinky SPEC stage 3 pressure plate is Kaput! That clutch NEVER worked well. Slipped on power shifts right from the beginning. I can't even spin 2nd gear on dry pavement.
Input on a REAL clutch to replace it ??..........not that this $400 clutch shouldn't have done the trick......SHEESH !
when I called about the slipping ..... immediately
. Here at my full-time job (catalog-mail-order-phone-internet BMW parts ... we're the biggest) ....... that would be the sure fire way of loosing a customer and everybody that he has contact with !!!!!
