I know this is a long shot, but does anyone know a good vehicle electrician in the Fresno area? The electrical on the GN is screwed up and its affecting the power brake system. If you keep the radio off, it lasts longer without blowing the fuse. But, a permanent fix is needed. Thanks in advance.
NFB: electrical work
Mods
87 GN - its just a 6...
Mods
93 Z28 - slightly tweaked
Mods
Tags: None
For most other cars, you would be right. However, the GNs came with an electric power braking assist system that creates its own vacuum so as not to use vacuum from the motor. Thus, if someone screws up the electrical, as they have on mine, it could be quite dangerous.Steve
Mods
Mods
Mods
First, I believe its a brand new unit. Second, how would you find out how often the motor is running? Third, and here's what tells us its the wiring...by turning the radio off, the brakes start working normal again. Any ideas?
***Edit***
Also, is the radio clock supposed to stay on even when the car is off and key is out of ignition?Steve
Mods
Mods
Mods
