Is there a K & N kit for a 97 Z with traction control? I see the slp but I'm not crazy about the design. Looks a little restrictive, and I don't like the small dual filters. What's a good CIA for a car with traction control? Thanks.
Which CIA? SLP or K & N?
Tags: None
To my knowlege, traction control has no impact on the CAI. I would recommend the Moroso kit. The price is lower, and performance the same.Originally posted by raroZ28Is there a K & N kit for a 97 Z with traction control? I see the slp but I'm not crazy about the design. Looks a little restrictive, and I don't like the small dual filters. What's a good CIA for a car with traction control? Thanks.
Check it out, Jegs has it for under $190 with free shipping
Moroso cold air at JegsTracy
Thanks Trace. The reason I ask is because K & N says that it will not work with it. Their FIPK. The moroso is the same price as the SLP, and I like the design too. Will a K&N filter fit on that CIA? Is it plastic or SS? I like how the SLP is SS. Do all 3 CIA's offer about the same level of performance?97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
All CAI kits offer about the same performance. What you are paying for is the look you prefer. The Moroso includes a K&N style oiled filter... it might even be an actual K&N??Originally posted by raroZ28Thanks Trace. The reason I ask is because K & N says that it will not work with it. Their FIPK. The moroso is the same price as the SLP, and I like the design too. Will a K&N filter fit on that CIA? Is it plastic or SS? I like how the SLP is SS. Do all 3 CIA's offer about the same level of performance?
That is very odd that the K&N says it wont work with ASR.. I've never heard of that before. Is there a component of the ASR system that would interfere with the installation?Tracy
here is more info... it was actully designed by Callaway.
http://www.moroso.com/catalog/catego...?catcode=34001Tracy
Thanks Trace. I'm sold
I have the Moroso CAI.
Yes it is.Originally posted by TraceZThe Moroso includes a K&N style oiled filter... it might even be an actual K&N??
The Moroso has a plastic tube and a metal mounting plate where it goes through the fender (so to speak).Originally posted by raroZ28Is it plastic or SS?
I had some problem getting mine on. I mounted the plate as far towards the outside of the car as I could and the tube was still too long. I tried a torch to melt the housing to try and get it to fit between the radiator and the ABS pump but that didn't work. I couldn't get the hood to close. I ended up cutting about an inch off the tube at the MAF end and it fit perfect (would have fit without the melting after this).
If I had to do it all over again, I would get the SLP.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Jeff... knowing what you know now, and how to cut some off the end would you be able to install another one without a problem? This is good info, thanks!Originally posted by Jeff 95 Z28I have the Moroso CAI.
If I had to do it all over again, I would get the SLP.Tracy
Probably. I would just like to know if it was designed long to be cut (The instructions didn't say anything about it.) or why is my car different than theirs ( http://www.callawaycars.com/callaway...rojects/c8.htm ).Originally posted by TraceZJeff... knowing what you know now, and how to cut some off the end would you be able to install another one without a problem? This is good info, thanks!
Interesting I can hear the intake a lot better. I think it resonates.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
The morosso knocked .3 seconds my buddy's 95 z. He went from 14.0 at 100 to 13.7 at 102. Im going to get the morosso when i get the $$$.1996 Trans Am:T-tops,graphite leather,16" chrome T/A rims, Nitto's, Descreened MAF, Morosso CAI, hypertech, flowtech cut out, 1LE elbow, Silver BMR tubular SFC's, 160 thermo, limo tint, harwood ws6 hood, !side molding, Stage 2 trans.
pure, did your friend have to do any fabricating to get the moroso to work?97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
No it went right on. a little pushing and pulling here and there thats about it.Originally posted by raroZ28pure, did your friend have to do any fabricating to get the moroso to work?1996 Trans Am:T-tops,graphite leather,16" chrome T/A rims, Nitto's, Descreened MAF, Morosso CAI, hypertech, flowtech cut out, 1LE elbow, Silver BMR tubular SFC's, 160 thermo, limo tint, harwood ws6 hood, !side molding, Stage 2 trans.
