Hey guys new to the forum and to f-bodies. Right now I have a 91 Camaro RS with the 3.1 V6. I have a 350 from a 91 Trans Am. What will I need to do to make the swap (y-pipe, exhaust, etc). Will the motor bolt up to my transmission or will I have to get one from a TA? TIA
v6 to B2L
darkknight1598Tags: None
for best results you should have a complete donar car to take parts from and also so you can see where it all goes.
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
Welcome to the forum. This question comes up here all the time. The answer is that it is not practical unless you have a complete running donor car. There are too many things that need to be changed. I did this exact conversion on a 1986 Camaro. I regreted it.
You'll need at the minimum:
engine complete with injection and all accesories, belt drive, etc.
engine harness and PCM
transmission with TV cable
engine mounts
transmission crossmember
radiator and hoses
new guage package for V8
V8 front springs to support the extra weight
exhaust manifolds, y-pipe and catback for V8
Limited Slip rear differential
I think the driveshaft can be re-used
many other little misc. piecesTracy
Welcome to the forum...
I really, REALLY want to see a V6 f-bud try this engine swap instead of the V6 to V8 thing...
LL8.
4.2L Inline 6 cylinder Chevy Trailblazer motor. Pretty large displacement for an inline 6... 4 valves, DOHC, with VVT. 270 base horsepower -- pretty significantly de-tuned.
I want to see someone do this some day
