What's the benefits of reverse flow?
Car overheating with engine off!!!!
Fred or someone else would have to give you a definite answer, but the obvious would be that for some reason detonation isn't as much of a threat in the LS1. Whether it's due to increased ignition efficiency or decreased compression or some other reason, I don't know.Dave M
t could be a clogged radiator. I had an over heating problem and decided to take it in. Turned out my radiator was clogged with leaves and debris. I also got a coolant flush and that took care of it. Also, a couple weeks ago I went diggin' underneath and found a Burger King bag sucked right into my radiator fans. It's always good to check on it once and a while.
Just wondering, how do leaves get into the coolant system?93 Trans Am; Hooker Cat-back;
Moroso cia; more to
come...hopefully!
Originally posted by ryan34So why did they convert back to conventional in the LS1?
Sorry just curiousFred
Originally posted by ryan34Is there anyway to convert my car to "reverse cooling". If so is it benefitial?
