Ok like it drives fine when iam cruisin... but when i stomp the gas... it has like a huge pause of not really giving it power then it kicks in at 5,000rpm .... thats dangerous... WHY?
Wierd problem.. Igition module?????
Originally posted by StolenBIRDOk like it drives fine when iam cruisin... but when i stomp the gas... it has like a huge pause of not really giving it power then it kicks in at 5,000rpm .... thats dangerous... WHY?
Seriously, if you want tech help, you should clue us in on what car, year, engine, modifications, etc...
not trying to be mean bro. trust me, everybody wants to help! just maybe some people are either kinda stumped on this one or they dont wanna stear you in the wrong way... im not a big fan of anything below 8 cylinders, and im not the greatest so i really dunno what to tell ya. Sorry and im sure somebody can help"Keep your Wheels a spinnin and the beavers a grinnin!"
My G Ride:
1985 Chevy Camaro
383 Stroker
Edelbrock Performer Carb, Edelbrock 6089 Aluminum Heads, Speedpro 4000 series Cam, KB pistons, Chromemoly Rings, Rollertip Rocker Arms, Holley Fuel Pump, Headers (w/ y-pipe), Torker II Manifold, Comp Magnum Roller Rockers, 4:11 Posi Rear, 700R4 Trans with reverse manual valve body w/ B&M Mega Shifter, & NOS
My car @ Cardomain
Originally posted by StolenBIRDBumping it back up since nobody seems to want to help.
Originally posted by StolenBIRDOk like it drives fine when iam cruisin... but when i stomp the gas... it has like a huge pause of not really giving it power then it kicks in at 5,000rpm .... thats dangerous... WHY?96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
Originally posted by StolenBIRDautozone has a free scanner mabey?96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
Originally posted by N20LT4BirdFirst, I think they have just a code reader. Even if they had a scanner, a scanner is only a piece of equipment. You have to know what your looking at, and if they did, chances are they wouldnt be working at autozone. Now, thats not to say you wont get lucky and run into a guy who knows his stuff, but your best bet is to take it to a good tech at a reputable shop.
i get a similar thing on my 83, firebird. when i start it up in the morning and every other blue moon, im assuming it's just a missfire from my old ass distributor cap and rotor or maybe my plugs or something like that? hell, i have no idea, but thats where imma start.'83 Z28 Camaro. 350/325HP, 3:73's, comp.cam, hedman headers, 650 carter carb, 1 inch spacer, edelbrock performer, K&N, 3" flowmaster, t-tops, 18" Torq thrust-II's and a big bad 4" cowl.
Originally posted by StolenBIRDI AM POOR96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
