Does anyone here know the best way to pull a 6-spd out of a 2001 camaro?!?!.... the tranny is already droped but i cant get the hydraulic clutch line off the transmission, i tried getting the bell housing off but its almost impossible since the bolts go from the housing into the tranny, but ive gotten all of the bolts off except 1 that sits behind the clutch line and i cant get a rachet in their and i tried a wrench but at the angle it goes in it doesnt grab the bolt enough and its rounding the bolt and help would be greatly appriciated
Help pulling down a T-56
Can you post a pic of what your talking about.....Ive dropped many T56's and im having a hard time picturing what your talking about. I think that is why you have so few replies.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
The LS1 has the slave cylinder bolted to the front of the tranny housing. It's a "pusher" design, unlike the LT1's "pullback" setup. There is no fork, the slave cylinder pushes directly on the T/O bearing. I think you need to disconnect the hydraulic line from the slave cylinder. The LS1 hydraulics also include a "bleeder" valve on the slave cylinder. I helped a buddy pull the T56 out of his 99 SS, and I know we took the hydraulic line off, but I also know he was installing the McLeod adjustable master at the same time, so I might have the process confused a little.Fred
