Hey guys,
I failed the sniffer a couple weeks ago. Its probably because I pulled off the AIR equipment on my car. Anyway, I was hoping you guys know some tricks to bring it down so that I can pass. I didnt fail by much. In addition to my mods below, I have:
-The timing advanced 8*
-The fuel pressure raised above the factory level
-A BRAND NEW High Flow Magnaflow cat.
-127,000miles
-I know my valve seals are going bad. On startup, I see a puff of white smoke come out the tail pipes. I am not getting in trouble for the smoke, cause its not visible, but mabey the small amount of oil that is getting into the engine while its running is hurting my emissions.
I was planning on droping the timing & fuel pressure back down to stock. Using a thicker engine oil for the test to stop any oil from getting into the combustion chamber. And maybe getting a new O2 Sensor. (I have to show a reciept for something when I bring it back to get tested) Any other tricks to help in passing?
I can bring it to a private testing center and "Pay a Fee" to get it to pass, but I would like to save a few $$ if possible.
-127,000miles
