Hello whats up everyone i am new to this message board...and i think it tight... but i need to know something bout some rims that i want to get...i was wondering if i get 18X9.5 10 spoke ZO6 rims all around with an offset of 53mm with 245 40 r18 what problems might come up would i have to modify my wheel well to put then on i have no idea any thoughts
Wheel and rim question
Im not sure about the offset because you didnt tell us what year the car is, as it makes a difference between 3rd gen and 4th gen,Im guessing 4th, but I am running 18x9.5 rims on my 89 and they fit just fine. No adjustment to the car made. and with 245 40 18 you retain stock tire height so you dont have to change your speedo. They actually fit better on my car with the 18s than the stock 245 50 16s that came with it.
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
That offset will work, and welcome to the board
Eric W.
6.2L/382.97 ci
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
9.5 inch rim with a 245 tire is too skinny. Generally speaking, a 9 inch rim has 275 series. I have 17X9's and I have 285 40 17. You can go 285 no problem with a 9.5 inch rim.2006 GTO Impulse Blue Metallic, Blue Leather Interior
Traded in: 1998 Z28
Yup. I'm also running 285's on all 4 corners with 9.5 inch rims.Originally posted by hotwhip99.5 inch rim with a 245 tire is too skinny. Generally speaking, a 9 inch rim has 275 series. I have 17X9's and I have 285 40 17. You can go 285 no problem with a 9.5 inch rim.Tracy
