friends got an LS1 Camaro and the transmission is generating a lot of heat and the center consol is just emenating heat and when the windows down and t-tops off and air ciruclation is flowin inside the car its REALLY bad...anyone know what causes this?
Lots and lots of transmission heat?!
-Rico
94 Camaro, 3.4L, M5, Quasar Blue, SOLDTags: None
Originally posted by Camaro4-2friends got an LS1 Camaro and the transmission is generating a lot of heat and the center consol is just emenating heat and when the windows down and t-tops off and air ciruclation is flowin inside the car its REALLY bad...anyone know what causes this?
Check the fluid?1996 T/A - BBK headers & throttle body, K&N filter, 1.6:1 Comp Cams Pro Magnums, Warbird hood w/ SLP Ram-Air
Thanks...I'll have him look into that.
What kind of problems can occur if he just lets this go.-Rico
He gets hotOriginally posted by Camaro4-2Thanks...I'll have him look into that.
No really, I have had the same problem with mine because the boot doesnt fit right - its never bothered me enough to fix it.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
