Ok, trying to trace down my .080 Amp draw. I have the following disconnected, and just made another check:
Alternator
Everything at the main distribution block (behind the battery, all the cars cables, NOT the battery cable)
Starter
Essentially, NOTHING hooked up to the battery. And the draw is STILL there!!!! The main positive cable is hooked up still, and I'm setting the multimeter to Amps, in line with the negative terminal on the battery negative terminal, and with the positive terminal on the negative battery cable.
What the heck could be doing this?
Alternator
Starter
