My buddy has a 94 Camaro Z28 that won't start. It will crank over and over, but does not get ignition. I'm not too familiar with Camaros. Is there a common problem in the ignition to check for? I know he changed his plugs and wires a while before it stopped working. He thinks it is the Opitspark, but the part is somewhat expensive. Is there anything else to check before replacing the optispark? Ignition module? Any suggestions would be appreciated.
94 Camaro Z28 won't start.
Before taking it appart check for spark, then fuel. If either of these is not there than you can go from there.
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
check the coil wire, some times where it connects to the coil it gets corroded or it pops off. coil is under the intake elbow bolted to the front of the drivers side head.Originally posted by foxxed84My buddy has a 94 Camaro Z28 that won't start. It will crank over and over, but does not get ignition. I'm not too familiar with Camaros. Is there a common problem in the ignition to check for? I know he changed his plugs and wires a while before it stopped working. He thinks it is the Opitspark, but the part is somewhat expensive. Is there anything else to check before replacing the optispark? Ignition module? Any suggestions would be appreciated.2000 WS6 T/A M6. Monster stage 3 clutch, flowmaster cat back, 4.10's, SLP lid, Hurst shifter.
past rides:
1994 Z28 A4 totaled
Some testing info that might help.Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
Thank you Norm. It does get somewhat proverbally annoying.Originally posted by Performin NormanPlease forgive me for correcting your spelling. I couldn't stand another thread with a Camaro spelled wrong. No insult intended.
No offense to the speller.
Sorry about the spelling guys. Next time I will spell CamEro right. Anyways, it's my friends car and has been sitting for about 8 months now. I just want to see it back on the road again.1984 Mustang GT Hatchback
Stock 80' 302
Comp Cam XE262H
Ported E7 heads
Summit long tubes
Weiand Stealth Intake
Holley 600cfm
Duraspark Ignition with GM HEI module
