I just bought a 1996 ws6 t/a and my ses, abs inop, brake, tcs off lights are all on. The car has bbk equal length headers, heads have been ported polished and cnc'd, it has dual 2.5" inch exaust all the way back, throttle body has been bored. It has an auto tranny with the lt1. my question is, is that its kinda slow. I didnt know with the ses light on if the computer is not letting the computer run right with the headers, exaust, and headwork. Is there anything i can do to make it run correctly? someone had said something about closed loop or open loop sumthin or other with the computer..??.. any idea?
new to f-bodies
First we need to know what code the ses light is signaling. If its something like the MAF or something, that can be the reason right there.
If you want your mods to operate properly with the PCM, you may want to have it reflashed to match your mods. I would suggest Ian at madz28.com. He is pretty inexpensive and does a nice job.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
Originally posted by Squat13or just throw a Carb on that Lt1 and be a man.
uhhhhh........no.
Having all the dash warning lights on simultaneously can be the sign of a problem with the electrical system, low system voltage, and the engine grounds. Did you buy it with all the dash lights on, or did they just come on one by one as you drove it?Fred
painted, and i bought the car with all the lights on, they never go off, always on.1996 Firebird Trans Am ws-6 a4
BBK headers
3in. Exaust with flow 80
Port and Polished Heads
58mill Throttle Body
Lowered an inch
2:73s... 3:42 goin in soon
2001 S-10
Air-Ride - SOLD
2003 S10
Lowered 6 inches
2005 HD sportster 1200 custom
Drag bars
Lowered 3 inches
The price you apyed sounds fair. It is a great looking car! enjoy!
It would be a good idea to see what codes are stored in the PCM to start.Tracy
