http://www.ststurbo.com turbocharge installed under the car not under the hood is that works better ? because i never knew or see one like that.
turbo
turbo
2001 Trans Am WS6 M6
Tags: None
There realy isnt much room in our cars for it, i have seen many people custom fab twin turbo steups etc . . . and alot of the time when the turbos are mounted up front the manifolds wind up hanging over the valce covers n crazy stuff like that. so i guess it makes sense to mount the setup in the rear i just dont know how much i like the idea . . .-Nick-
95 A4 Z28
What about lag??? I guess its a big enough turbo that there isnt very much lag running everything all the way to the rear???Originally posted by 95z28There realy isnt much room in our cars for it, i have seen many people custom fab twin turbo steups etc . . . and alot of the time when the turbos are mounted up front the manifolds wind up hanging over the valce covers n crazy stuff like that. so i guess it makes sense to mount the setup in the rear i just dont know how much i like the idea . . .1996 Z28 body, the rest...drag car
Oddly enough, they say that lag really isn't a huge problem with it...
Look it up in the "forced induction" section of ls1tech. www.ls1tech.comFormer Ride: 2002 Pontiac Trans Am WS6 - 345 rwhp, 360 rwtq... stock internally.
I have twins on my 2001 z28 and the new turbo manifolds were up a little higher than the stockers. This caused a clearance issue with the coils still mounted on the valve covers. The plug wires were touching on the hot pipes and burning through. The coil relocation kit from Thunder Racing solved that problem.
There was a guy locally who did the STS recently on a stock 2002 WS6 CE. He was saying that he has full boost by 2800rpm and that he probably picked up 100 hp. The install only took about 8 hours(first time, should get it down to 4-4.5 hrs). He was saying that he pulled on a 2003 Viper from a roll
I really like the idea of the rear turbo and think that when I get enough money I will have one installed. Even if it gives you 5 hp, the sound that the exhaust makes in sooooo sweet and well worth it
. When full boost hits it sounds super sexy
97 SS #C007
Polo Green w/ tan leather A4
A guy I know recently had one installed this weekend, Far more reliable tune than his D1 procarger with intercoolers. It is still early and no good tune yet, he ran only 9lbs of boost (at 2500 or so rpms
) .. safe to say it has enough power in Fourth Gear to launch a radar detector from the window and cut his passengers wrist. He has a forged LS6 block, and plans for an even better block. He runs an intercooler to boot with on top of the regular package. He says this system is far easier to tune, and blows his 630rwhp D1 procharger setup out of the water
Of course this is just installed. It will be interesting to see how his setup will do with proper tuning
pics and info
