The clutch fork pivot ball (actually a "t" bolt) is mounted on the front of the tranny. The slave cylinder is mounted on an aluminum cup, on the bellhousing, right next to the tranny, facing forward. When you push on the pedal, the slave cylinder pushes the outer end of the clutch fork forward, meaning the inside end of the fork "pulls back" on the T/O bearing to release the clutch.
LT1 T56:
The T56 used in the LS1 cars was changed. There is no fork. There is a hydraulic slave cylinder mounted on the front of the tranny, concentric with the input shaft. When you step on the clutch, the slave cylinder "pushes" forward on the T/O bearing to release the clutch.
You can't really compare a Corvette tranny... they didn't use the T56 with the C4 LT1's, and the T56 in the C5 LS1's is mounted on the rear differential housing.
LT1 T56:
