Here is the story, I have a 95 z28. The clutch engagement is very high on the pedal, you only have to push it maybe an inch or two disengage drive.
If you try to launch hard in first from a stop, assuming the tires hook up you can here a sluggish reving and see the tach move but not proportionally to the speedometer. If you drive 70 in fifth or sixth, clutch it, rev it up high and pop the clutch the rpm's stay high and slowly drop to normal, definitely not any kind of near immediate lock up.
This is the second OEM, could the problem be somthing else, maybe slave cylinder. It has plenty of fluid too. Is there an adjustment.
Plus you can smell it burning during hard use too.
Thanks
Thanks
i guess that damn gremlin ran off
