I currently have a M6 in my 95z, I put 510rwhp and 520ftlbs to the wheels. How much power will I lose going to the th400?
Th-400 question
http://www.transmissioncenter.net/Originally posted by Juicedzany recommendations on where to buy a setup like this? transbrake, converter, flexplate, tranny, etc?2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
The gains of a high stall and a brake will total negat the power loses. You will understand when your yanking the front after dumping the break. Also it will be much more consistant in trap times.1967 VW Bug 2.3L Ford SVO Inline 4 w/ Turbo, Sand-Drag VW Trans Axle, Race this Import.
Actual numbers, calculated by running the engine on an engine dyno, with full intake and exhaust, then installing the engine in the car and measuring rwHP on a chassis dyno.
Engine dyno:
NA: 486HP
1-stage N2O: 633HP
2-stage N2O: 762HP
With a steel flywheel Street Twin, stock T56, 3" chrome moly driveshaft, Strange 12-bolt with 3.73 gears, 17x9.5" wheels, with 275/40-17 tires:
NA: 425rwHP (12.6% loss)
1-stage N2O: 555rwHP (12.3% loss)
2-stage N2O: 670rwHP (12.1% loss)
Switch to a TH400, high stall, high slip, non-locking convertor (5,000rpm flash at 800 lb-ft), same type driveshaft (different length), same rear and gears, 15x10 Weld Pro-Stars w/ 28x11.5-15 QTP (which clouds the issue a little):
NA: 390 rwHP (19.8% loss)
1-stage N2O: 505rwHP (20.2% loss)
2-stage N2O: 600rwHP (21.3% loss)
Interesting thing is, for the reasons pointed out above, the car did not see any appreciable loss of 1/4-mile performance..... the "area under the curve" is not reduced. The peak HP may be lowered, but you get a huge increase in torque off the line, and the high stall convertor holds the torque high. Car still runs approx 117MPH on motor, 128MPH on a 125-shot at 3,760# race weight. No numbers for the current 300-shot.Fred
