Do you guys think the moroso cold air intake will fit/work on a TPI car?
moroso CAI ???
No. the TPI cars are 3rd gen. The Moroso is designed for a 4th gen LT1 car.Originally posted by ryan34Do you guys think the moroso cold air intake will fit/work on a TPI car?
Two completely different designs. You might be able to hack it up and make it fit?Tracy
The intake for the TPI is cold. It takes air from the nose. You can remove the baffles from the nose panel and open it up a bit. I have never seen an aftermarket intake for a 3rd gen TPI Camaro.Originally posted by ryan34Do you know where to find a CAI for the TPI? I can't seem to find them.
I'd recommend getting a couple K&N filters and removing the baffles.Tracy
SLP makes aftermarket intakes for 3rd gen TPI F-bodies. I agree with TraceZ though, just get some K+Ns, remove the baffles, descreen the MAF (if equipped), and do the throttle body coolant bypass, and you'll get plenty of cool air.Originally posted by TraceZThe intake for the TPI is cold. It takes air from the nose. You can remove the baffles from the nose panel and open it up a bit. I have never seen an aftermarket intake for a 3rd gen TPI Camaro.
I bet you could modify the Moroso CAI to work, but I have no idea what all would be required.
Here's a link: www.slponline.com . Just click on 82-92 F-Body, then Induction.1991 Chevy Camaro RS (Is it plum or purple?)
Engine: 305 TBI (L03)
Trans: TH700R4
Mods: Some
CarDomain Site
