my window motor died and one of my friends has a 1995 firebird she said its a pain in the *** to replace window motors im just wondering if i should do it myself anyway or if anyone knows how much it would cost to get a shop to fix it.
window motor
Shoebox has the directions for the fix on his site. Get a lifetime warranty replacement at Autozone or similar joint for around $60, plan on a couple of hours for the first one since you have to drill out 4 mounting riviets.The Old Guy! '94 z-28, m-6, t-tops, go-fast red, 316k. Now with '96 engine w/ Lt-4 hot cam, roller rockers, heavy duty timing chain, and Spec stage 2 clutch.
Fairly easy if you follow this: http://shbox.com/page/windowmotor.html
Window motors are $75 on average at local auto parts stores.
There are only 3 mounting rivets, not 4. I just replaced one today in about 45 minutes.
Follow Rob's instructions on his website.
Also, please be aware we have a SEARCH feature on this forum and you would had gotten your answer easily that way without posting the question again.Tracy
Took a half hour for me my first time, it's not all that hard. Just print out rob's pictures, it'll save you trips back and forth to the computer.
And if anybody can tell me if it sounds like their glass is slamming if they shut their door with the window cracked, I'd appreciate it. It's annoying, but I pulled my door panel and I can't figure out how to fix it....97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
Originally posted by raroZ28And if anybody can tell me if it sounds like their glass is slamming if they shut their door with the window cracked, I'd appreciate it. It's annoying, but I pulled my door panel and I can't figure out how to fix it....
to adjust them you should do the rear bracket first. lower the window 2", push the window out until it touches the exterior weather molding. Now move the bracket twards the window until it nearly touches it and tighten the bolt. Now do the front one by moving it in until it nearly touches the window and tightening it.
Be carefull not to move them too close to the glass. It could result in too much friction and scratch the glass. Once you are done the window should be able to wiggle 1/16" freely between the stops and the weather molding.
It would also be a good idea to give the window tracks a good once-over and lubricate them. Make sure all the mounting bolts are tight.Tracy
My passenger window would roll up and down slowly then stall bout 3/4 the way up and it would take a while to get enough power to roll all the way up so i had a guy replace the motor and it cost 100 bucks to replace and he seemed to have a heckuva time with it also. Would not want to do it myself. Also i seem to have the same problem as you. When i shut the door with the window rolled down a little, it sounds aweful and seems like it could break when shutting it.
I've done the motors in my Z myself. Piece of cake. Follow Rob's (shoebox's) instructions and you'll be done in a snap. It is a piece of cake if you follow the instructions.Steve
87 GN - its just a 6...Mods
93 Z28 - slightly tweakedMods
Originally posted by raroZ28Took a half hour for me my first time, it's not all that hard. Just print out rob's pictures, it'll save you trips back and forth to the computer.
And if anybody can tell me if it sounds like their glass is slamming if they shut their door with the window cracked, I'd appreciate it. It's annoying, but I pulled my door panel and I can't figure out how to fix it....Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
Thanks rob97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
