I have a driveshaft vibrations and i was told that an aluminum driveshaft will cure these problems. Where do i pick one up from? What car are they off of? How much do they generally cost, and will i pick up any time in the quarter becuse i loose 6 pnds of rotating mass or something like that i was told.
aluminum driveshaft
A 1LE shaft will run about $280 shipped from Pace Parts. The part # is 10085375. I have heard bad rumors about using the LS1 shaft, but they may just be rumors.Steve
Mods
87 GN - its just a 6...
Mods
93 Z28 - slightly tweaked
Mods
I've heard that the LS1 shaft isn't quite as strong as the 1LE shaft. Craig could probably shed more light on it, but if I remember correctly, he found a post on cz28.com (I believe) that someone used the LS1 shaft on their LT1 car, put either drag radials or slicks on a twisted the shaft. Not sure what rear-end was being used. I'll talk to Craig and see if he can shed more light and correct me on this. As I said, I'm not sure as to how true it is, but I'll get Craig.
*** EDIT ***
I did a quick search on cz28.com and found this...
http://web.camaross.com/forums/showt...aluminum+shaft
Look at post #7Steve
Mods
Mods
Mods
Check this Ebay seller they always seem to have one for auction.
http://cgi.ebay.com/ebaymotors/ws/eB...category=3373897 Trans Am A4 more or less stock (Mods: WS6 Ram Air with Fernco & K&N, 12 disc CD changer, power antenna, SLP Fan Switch, LS1 Aluminum DS, Borla Cat back, McCord power plate, Spohn tower brace, Sirius, HID fog lights)
joe.. so i take it the ls1 driveshaft from the factory, which would in theory be on my car, is aluminum?2006 GTO Impulse Blue Metallic, Blue Leather Interior
Traded in: 1998 Z28
Yes it is. It is a different diameter than the 1LE, but it is still an aluminum driveshaft.Steve
Mods
Mods
Mods
Here it is...an LS1 driveshaft. Supposedly launched at 3500 with a CAI and cat-back for power mods only.
http://camaroz28.cardomain.com/membe...=348183&page=394 Black T/A GT, Advanced Induction 355, 3200 stall, built 4L60E, Moser 9", Baer Brakes, Shooting for 11s...
z28_xxx
When did this problem start?
Originally posted by redbird94I have a driveshaft vibrations and i was told that an aluminum driveshaft will cure these problems. Where do i pick one up from? What car are they off of? How much do they generally cost, and will i pick up any time in the quarter becuse i loose 6 pnds of rotating mass or something like that i was told.
Quite possibly a manufacturing defect. I have seen the stock LS1 driveshafts hold 500+ RWHP consistantly.Originally posted by Craig 94 TA GTHere it is...an LS1 driveshaft. Supposedly launched at 3500 with a CAI and cat-back for power mods only.
There was an article not too long ago in GMHTP that featured a 700 RWHP Camaro that ran the stock LS1 DS for over a year on a M6 with no problems.
