i just put a loud mouth on my camaro a little while ago, and removed the cat at the same time. i know that not all mods work good with out other ones to back it up, but we put it on the dyno last night and it made 183 hp. last time when it was stock with factory plugs and opti with 112k on it tossed down 238 hp. i have put in a NEW opti, and new plugs, removed the cat and put on the loud mouth. WHAT do i do now???? what can i do to take advantage of the loudmouth, or should i ditch it?
up set about massive power loss with SLP loudmouth
past rides:
1994 Z28 A4 totaledTags: None
That sounds like a considerable loss in HP. I would not blame the LoudMouth. I took a quick dyno to get an idea of what my car is before headers/y-pipe/catco, and without nitrous. 275.7rwhp/294.6rwtq
This was 1 run no cool down, and an alternator putting out 12.2 volts at WOT.
Save yourself some trouble and get the cable from akmcables, and atleast try the free scanning software.
Check your wires too1995 Firebird Formula
13.410 @ 102.66 11/20/05]
Originally posted by Formulaboy95That sounds like a considerable loss in HP. I would not blame the LoudMouth. I took a quick dyno to get an idea of what my car is before headers/y-pipe/catco, and without nitrous. 275.7rwhp/294.6rwtq
i got the cable and no issues that i can see, before or after the run. i wonder if my tranny is slipping? the car runs like a top, and will lay down the rubber from a dead stop like its on ice. if i punch it in second gear it will light em up pretty easy. it is an A-4. i dunno, i am so pi$$ed that i want to sell it and get out of cars all together.2000 WS6 T/A M6. Monster stage 3 clutch, flowmaster cat back, 4.10's, SLP lid, Hurst shifter.
past rides:
1994 Z28 A4 totaled
you say you had 275.5 hp at the rear wheels with a stock LT-1? thats like 3% drive train loss. not to doubt you but a 285 hp car with an auto (if you have that) should be right around 238~240 hp at the wheels.2000 WS6 T/A M6. Monster stage 3 clutch, flowmaster cat back, 4.10's, SLP lid, Hurst shifter.
past rides:
1994 Z28 A4 totaled
1995 Firebird FormulaOriginally posted by azkknyou say you had 275.5 hp at the rear wheels with a stock LT-1? thats like 3% drive train loss. not to doubt you but a 285 hp car with an auto (if you have that) should be right around 238~240 hp at the wheels.
Ram Air w/ K&N, TransGo Shift Kit w/3 washers ,SLP~Shorty headers, LoudMouth, Air Foil, LineLocks, 1LE trans mount. Catco Cat. Hypertech 160 & Fan Bypass. Redline Water Wet. TB Bypass. MSD~8.5mm Super Conductor's & Blaster coil. FastToys MAF ends. IAT Spoof. LT4KM. BMR~Adj LCA's, Rear sway, Panhard rod. HAL QA1 rear shocks. Random Tech adj TQ arm. Nitto NT555R's. Covered in Zaino. NX 50 shot w/ NX goodies - Bottle empty Waiting for fuel pump.
....... you know I dont call that stock. Doyou?
1967 VW Bug 2.3L Ford SVO Inline 4 w/ Turbo, Sand-Drag VW Trans Axle, Race this Import.
azkkn -
Are you saying that the car is still fast and you don't feel a difference?
If you don't feel a difference, there probably isn't much of one and the dyno was f-ed up. Trust me, you would feel a 50 HP loss. There is also no friggin way a cat-back takes away 50 HP. Pretty mechanically impossible.
Do pushrods bend in LT1s like they do in LS1s? That might be your culprit........Former Ride: 2002 Pontiac Trans Am WS6 - 345 rwhp, 360 rwtq... stock internally.
not at all, but he stated he dynoed ot before adding that stuff.2000 WS6 T/A M6. Monster stage 3 clutch, flowmaster cat back, 4.10's, SLP lid, Hurst shifter.
past rides:
1994 Z28 A4 totaled
i am just currious if the loss of back pressure is my problem.2000 WS6 T/A M6. Monster stage 3 clutch, flowmaster cat back, 4.10's, SLP lid, Hurst shifter.
past rides:
1994 Z28 A4 totaled
That says with out Hearders/ y pipe/ Catco and spray. There are still many things dont to that car beside that.1967 VW Bug 2.3L Ford SVO Inline 4 w/ Turbo, Sand-Drag VW Trans Axle, Race this Import.
if he spun a bearning...he'd know it...Originally posted by Squat13I beat you were missing, have a spun bearing, or just have a messed up dynp.
i knew it right away.. and drove slowly to the dealer.
you wont loose power with the loudmouth. not at all. other probs like the folks said.
i had it on my compTA.. it was one of the first lt1's to get it... and we have it on the firehawk...which just has bolt ons... no power loss at all. quicker gains in the higher rpms.
