I'm planning on doing a pretty major suspension upgrade to my T/A this winter and I was wondering what some of you suspension gurus thought of this set-up. I was planning on going with the eibach spring and bilstien shock combo from SLP. Then I was planning on going with the BMR tubular lower control arms with some LCA relocation brackets and adjustable panhard rod. Then to finish up I want to add the BMR 32mm front swaybar and 21mm rear swaybar.
I really just want to lower the car a little, improve the handling quite a bit over stock, and create a better platform for future power adders. I'm not talking about a suspension that will allow me to pull 1g or hold up to 500 hp but definitely improve the handling. I've already got a strut tower brace, subframe connectors and 17X9.5's with 275/40/17's. Is there anything else you guys would suggest.
Thanks in advance.
Thanks in advance.
Good stuff!
13.410 @ 102.66 11/20/05]
