Thankfully emissions testing has come to my area yet. A previous owner removed some of the emission components from my '82 trans am and also bypassed the EGR valve. I want to get the emission working in my car, however, my dad believes that it's pointless. He says that it would takes thousands to replace the emissions. I calculated the cost, it would cost about $1500, not including shipping, to put all new emissions in. This is out of my price range. I just want to know what emissions have been removed and what emissions in the car still work. Does anyone have a procedure for testing the components and fixing the EGR valve? I'd really appreciate it.
Emissions
retard the timing
use DRY GAS
use that guaranteed to pass stuff
lower your car so low it is below the limit to go on the rollers. IF your car is too low, in some states, they cannot do the rolling test because putting the car on the rollers will cause damage
also there is a $$$ limit on attempts passing emissions. If you spend X-amount of money to pass emissions, and still fail, they must pass you (at least here in RI its $500 )
best advice I could give you, get in good with the local smog shop
pics and info
Power Drain & Stalling
There's a major power drain on my trans am. If it for the weekend the battery is dead. It has died on me a few times recently, always at the corner one house down the street from my house. Before dying, the idle is somewhat rough, and i'm using extra stuff; first it was the defrosters, then this mourning i think it was the headlights. When the dying keeps occuring, turning the headlights or defrosters off will cause the car to run fine. The problem is that when crossing a busy street, you hope you dont need that second chance. Another thing is that, when the car is warm, the defrosters will act as cruise control, they will maintain high levels RPM. The battery was bought back in June of this year, and the alternator was tested yesterday, it had no problems with it. What could cause these problems? I thought it was the alternator but i guess i was wrong.1982 Trans am w/ t-tops
previous owners abused it!!!
Agree...i know a couple people who have done this to get by emissions here in illinois.Originally posted by Rhode Island Redretard the timing
use DRY GAS
I don't know the illinois law on lowered cars for a rolling test, so i cant help ya on that one.
As for your power drain problem, a buddy of mine had a similar problem not too long ago on his 84 firebird, but not as extreme as yours. It wound up being a grounded wire i believe
I am in no way an electrical expert though, so i'm sure someone else may be able to shed a little more light on that subject.
BTW, where in illinois are you?
~Chrisblack 95 t/a, a4, beefed up tranny w/ higher stall converter, transgo shift kit, trans temp gauge, trans cooler, richmond 3.73's, loudmouth, hypertech programmer, 160 thermo, descreened maf, TB bypass and airfoil, trick flow intake elbow, underdrive pulleys, moroso cai, edelbrock panhard rod, bmr stb, slp sfc's, fiberglass firehawk hood, hawk pads, taylor wires, ngk plugs, royal purple fluids,...and hopefully more to come
