for christmas should i get lower control arms and panard bar, or subframe connectors.
panard bar, and lower control arms or subframe connectors
hey bud............
go with the SFC first..........
then LCA and relocation brackets if your car is lowered............
then adj. panhard rod........
i got the LCA's already getting the other stuff soon....
eddie
"Reduce chassis flex to a minimum and increase your handling capabilities" http://www.bmrfabrication.com/F-body...frameconnector It's hard to describe a feel but once you put them on you will understand. It makes it feel more like a Corvette. They definitely make the sway bars work better.Originally posted by redbird94why those first?2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
If you want to improve straight-line grip, then go for the LCA's and relocation brackets. Then things like aftermarket adjustable torque arm, larger rear sway bar, etc.
If you are looking to improve the overall handking characteristics of the car, then go for the SFC's and a larger front and rear sway bar with poly bushings. The SFC's really make a big difference and they will help to get of any chassis rattles you may have as well.
I cast my vote for the SFCs. Best $300 I spent was the SLP bolt-on SFCs...which may just get welded on down the road. Either way, you'll love the way they make your car ride and handle.Steve
Mods
87 GN - its just a 6...
Mods
93 Z28 - slightly tweaked
Mods
