I need to recalibrate my 4L60 for my 3.73 gears. I was just wondering where the drive and driven gears are located on the 4L60 and what do I need to do to get to them and replace them? I know that the drive gear is located around the tailshaft of the tranny. Do I just need to take the driveshaft off to get to it or is there more to it. I have no idea where the driven gear is located on the tranny. anybodies help would be greatly appreciated.
Where are the speedo drive and driven gears?
1993 Formula - 99k
Throttle body bypass, K&N FIPK II, SLP Loudmouth, Mad Z28 Chip, 3.73 motives, TPI airfoil, Spohn LCA relocation brackets, Fuddle 3200 Stall, B&M Supercooler, LS1 driveshaft, and chrome ZR1's 17"/9.5" and 17/11" in the back!!!
Tags: None
Yes, the gear is located on the tailshaft (output shaft) housing. You will just need to remove the one bolt holding on the driven gear housing and then remove the spring clip that holds the speedo drive gear to the output shaft. With a 15 tooth drive gear and a 26" tire, you will want to use the purple 43 tooth drive gear. Part#1362196.Originally posted by blackfire93I need to recalibrate my 4L60 for my 3.73 gears. I was just wondering where the drive and driven gears are located on the 4L60 and what do I need to do to get to them and replace them? I know that the drive gear is located around the tailshaft of the tranny. Do I just need to take the driveshaft off to get to it or is there more to it. I have no idea where the driven gear is located on the tranny. anybodies help would be greatly appreciated.
What side of the housing is the driven gear located on? Will I have to take the driveshaft off to get to the speedo drive gear on the output shaft? Also how much of a difference would a 44 tooth driven gear and a 43 tooth driven gear make in the speedometer because knightfire says to use a 44 tooth.
***Speedo Correction Gears for 93 LT1***
GM p/n 25513052 (44 tooth driven gear) $12.78
GM p/n 8642620 (15 tooth drive gear) $7.56
2.73= 17 tooth[red] and 37 tooth[red]
3.08= 17 tooth[red] and 42 tooth[green]
3.23= 17 tooth[red] and 44 tooth[dark gray]
3.36= 15 tooth[gray] and 40 tooth[black]
3.42= 15 tooth[gray] and 41 tooth[yellow] This is mine
3.55= 15 tooth[gray] and 42 tooth[green]
3.73= 15 tooth[gray] and 44 tooth[Light blue]
4.10= 15 tooth[gray] and 49 tooth[NONE]
KnightFire
1993 Formula - 99k
44 tooth would be for a ~25.5" - 25.9" tire. 43 tooth is for a ~26" - 26.6" tire.
Just depends on what size tire you have on the rear. Here is a tire diameter calculator:http://murray.faithweb.com/formulas.htm#find_rear
